Re: Winch strap issue
Here is a pic taken a few years ago after I re-positioned the winch so that it allowed the bow stop to be above the bow eye. It used to be on top of the stand and towards the rear and obviosuly turned 180 degress from what you see here. It might be hard to tell from this pic but the strap comes off the top of the spool...do you think it would be better if it came off the bottom?
EDIT: I've added a 2nd pic below that shows the previous position of the winch. This is the way the boat/trailer came brand new in 1972 and when I inherited the boat from my father a few years ago, I did the modification knowing that the bow stop should be above the bow eye.
2nd EDIT: I found an up-to-date pic below...the strap does come off the bottom after all. Now I recall reversing it a while ago so that the the tightened strap and the end of the bow eye are in as straight a line as possible. Also, in this pic the strap is loose which is why you see the gap between the bow stop and the bow eye. I take most of the tension off the strap whenever I let the boat/trailer sit and
always re-tighten it before moving the trailer/boat. And yes, there is some clearance between the spare tire and the bow.
