airdvr1227
- Jul 15, 2009
- 1,666
Re: is OMC really that bad?
Opinions are like...
Misery loves company.
If you own an OMC, you have to be able to justify your owning one. The fact remains. OMC is Dead>>>>>>> DOESN't exist anymore.
If you can fix the drive and all the OMC stuff yourself. then you will have problems.
Why BUY that problem to begin with.
If you can't fix the drive, and there aren't any techs around to fix them. Well, you are just flat stuck with buying used junk off the internet.
Why put yourself in that position to begin with.
Here's just one of a few websites I have saved that offer OMC parts and tools:
http://www.sterndrive.info/
I don't think there's one part that I can't have ordered and replaced by someone else in town for my entire engine and out drive. I just prefer to do it myself.
I also didn't have to look very far to find two locals who work on OMCs... and that's in the middle of Kansas.
I think if you stay away from the boat dealerships that look like cell phone stores you'll be able to find plenty of people willing to work on OMC drives. Of course I wouldn't really recommend even taking mercruisers to cell phone dealerships.
It's not like we're defending bad drives. The stringers have several advantages over Mercruisers. They just have a few problems you need to be familiar with... but so does Mercruiser who also has several advantages over the stringer.
Now the Chrysler out drive I had.... I couldn't find a single part for that piece of junk!
I just got my impeller kit from napa and I did not have to pull the lower unit off my outdrive to change it like on the m well you know.
It took me about 6 hours the first time I did it. I didn't have a manual and I did it without disconnecting the shift cable stop on the intermediate housing. :redface: Readin the manual sure sped that process up.
Let's time how long it takes a Mercruiser mechanic to remove an entire upper and lower mercruiser vs any one of us to remove an entire upper and lower stringer drive.... Then let's put the boat back in the water and see which one floats longer.
Well.....NO...OMC was never "BAD"
It's not really a valid question anymore anyway.
Is it "smart" to buy a used boat with an OMC engine/drive installed? Maybe, and Maybe NOT.
It will depend on which model and how able you are to work on it.
If it's the "wrong model" I.E, the model that the "after-market" no longer supports with normal or typical "wear Parts"........Then DO NOT BUY it.
If you're looking at one that is completely supportable, (and you're capable of doing the work or you know someone that can do typical work on it, then it's might be ok) BUT YOU NEED TO DO YOUR "HOMEWORK"
Otherwise, stick to an engine & drive system that has a company still in existence!!
The facts are, OMC is no longer around. As time goes on, supported drives and OMC specific engine parts will eventually become more and more "scarce" and you'll be getting more and more "parts" from wrecking yards, etc....Pay attention to those facts
Can't we all just get along.
.....Misery loves company.....
AHHA! That explains all the Mercruisers.
