86 or 87 30hp loses prime
chucknsuzie
86 or 87 30hp johnson loses prime, when it is dying if i squeeze the bulb it will pick up. rebuilt fuel pump changed all fuel lines and conectors. i need help
quackaddict1
Re: 86 or 87 30hp loses prime
IS the tank connector working properly? Are all the clamps tight on the fuel lines?
schematic
Is your tank vent free and clear? Does it still require priming if the cap is left loose?
chucknsuzie
yes i replaced the conector on the fuel tank and the vent is open.
tashasdaddy
really sounds like a fuel pump, of stuck float needle in the carb, not allowing fuel in until you force it with the bulb.
