omc cobra
xltier
i have been trying to find the area in the manual where it explains the shift cable adjustment for a 94 omc cobra.it doesnt seem to be there.i also checked a factory cd i bought and i cant find it there either.i get the bellcrank at 90 degrees and adjust the cable to get the 75/8 at the plate end,but whe i put the drive on it all goes out the window.cable drags hard also when its all put together.its a new cable and all works well individually.can anyone help.another weekend is coming.its a 94 four winns 3.0 omc cobra.super low hours.very clean.stored 7 years.thanks.
danond
Re: omc cobra
Toward the end of section 6. Do you have an actual OMC factory manual or are you using the SELOC one?
xltier
Re: omc cobra
its a cd that says OMC 1985-1998.thats all it says.got it on ebay
danond
Re: omc cobra
Get a real service manual. That's a SELOC CD. Go back to eBay, find an actual OMC Service manual for your year drive (it will cover one year only) and you will find everything you need!
xltier
Re: omc cobra
i think i found one.plenty for the king cobra.i also checked the manual at the top.i downloaded it to my pc and its just the same thing.thanks
xltier
Re: omc cobra
i have printed out all the hastings pages and taken them out to the boat.thats where i got the other measurements.but the pic of setting the shift rod height is not working for me.is the measurement from the top of the v-notch plate to the case where the anode is.if so,mine is about 3/4 inch off.pic isnt very clear.thanks
Gary H NC
Re: omc cobra
Did SeaRayman fix you up?
You will like the oem manual...SO much better!;)
