luv2fishN.M.
Thread starter- Joined
- Mar 9, 2009
- 48
i have a 1989 mercruiser with the 4.3 we were out on the lake last weekend and the alternator amp gauge spiked all the way up. shortly after we smelled something like electric smoke coming from the motor. we killed the motor and found the big red wire that connects to the alt had melted off and the alt had some smoke coming out of it. now the motor will not start. i checked the pos to the coil and it has 9.7 volts. i took the coil wire off the distributor and tested against a ground for spark. could not see any, but it shocked the hell out of me! also the coil was piping hot. so i bought a new one. still nothing. any advise? has anyone ever had this problem? what should i test for? also will the motor start w/out the alt installed ? thank you for the help
