Bearing buddies leaking grease ??
pecheux
As recommended I installed bearing buddies on my boat trailer then loaded them with water-resistant grease. Problem I see is that grease leaks out from the outside or the buddies ... I thought the grease was on a one-way direction towards the inside bearing ??? Is there anything wrong with the buddies ??? like a broken seal or something ??
Thanks
bruceb58
Re: Bearing buddies leaking grease ??
You probably over filled them. Only fill until the diaghram just starts to move.
kenmyfam
Agree. You can have too much of a good thing !!!
QC
This should be a Stupid Human Trick post, but I once had my trailer bearings repacked at a Winston tire store. I was in a hurry, whatever, had them do it. The flippin' honkin' imbecile idiot guy packed the outside of my bearing buddies and put the bras back on . . . :eek: :mad: :rolleyes:
Jeff-in-PA
Here's a picture of my bearing buddies BEFORE I added grease to them thru the zerk fitting. The plate only needs to move a 1/4" to have plenty of grease in them.
Jeff
pecheux
Then that must be the problem since I pumped grease as long as the diaphram kept on coming outwards, then stopped only when it stopped moving ... so I must have overfilled ...
Thank you, and tx to everyone else who gave me feedback
Tafflad
I have just bought a pair of these - not fitted yet.
These have the visual Blue grease level indicators .... anybody any experinece of these ?
pecheux
These are the model I have installed on my boat trailer. In comparison to the ones showed in above picture the indicator is on the outside instead of inside. Everything else is exactly the same.
QC
Ironic that the pic has grease coming out behind the bearing buddy :D
Jeff-in-PA
I just got done hand packing the bearing and filling the hubs with grease before I installed them. I tapped in the bearing buddies and took the picture.
I'll wipe them clean next time before the picture ;)
pecheux
What type of grease is this blueish/green product ??
Anything to do with being water resistant ??
Cheers
wbeaton
I can tell you from my experience that its very easy to overfill Bearing Buddies. I bought a trailer that had new bearings and Bearing Buddies a few years ago. Having never used them before I thought they'd be like added insurance. After a long road trip I checked the buddies and found that there was no movement in the spring at all. So, according to the instructions I filled them with grease until the spring began to move. Unfortunately, for me it seems the rear seal blows out at a lower psi than the Bearing Buddy spring moves. I ended up overfilling the axle and blew out the rear seal after my first trip. It was a hard lesson. I would have been better off leaving them the heck alone.
pecheux, the blue/green grease is water resistant axle grease like the Canadian Tire store brand.
bruceb58
People that give the Bearing Buddys a shot of grease before every trip are the same people that are blowing a shot of grease out the rear seals and onto their brakes every trip.
Al Kungel
I just replaced the bearing buddys on my boat trailer and I was surprised that the new ones have a 1/16" hole drilled in them which will expell the extra grease.
j_martin
You shouldn't be able to blow a grease seal with the bearing buddy. The spring tension isn't that high. However, I've seen many scarred sealing surfaces, and also a few that were quite a bit undersized, and not able to hold pressure.
Bearing buddy markets seal kits that have a stainless steel seal surface that fits over the original, and is sealed to the hub by an o-ring between the new seal ring and the inside bearing. A high quality neoprene seal completes the application. It's great.
When you first install a bearing buddy, there will be some air in the hub. It'll burp out as you roll, so you might have to add a squirt of grease both at the loanding, and at home for a few trips. Eventually it'll fill up and you can leave the grease gun home.
The only other thing I've found is that they can shake off on bad (washboard) roads. I wipe the hub as clean as I can and install them with a coat of locktite sleeve retainer. It takes heat to remove them, so a repack has to be done orthoscopically through the bearing buddy, or you have to heat it to remove it, and then replace the o-ring on the diaphragm. Neither scenario is a big deal.
hope it helps
John
redone4x4
yep, mine too. i just filled em up reaaallly slow until i just barely saw some grease ooze out the relief hole. wiped it off, towed a few miles, checked it again, and it was all good. the dust caps will just barely cover the reliev hole if i remember correctly.
wbeaton
That's what they say, but here I am with grease all over the back of my hub. Mine also has the hole to expell excess grease.
j_martin
Well, your seals are defective. With or without the bearing buddies, the same seals will admit much water when immersed, with negative effects on the wellness of your bearings. Consider yourself fortunate to have found this dangerous defect so easily.
Get the number off the inside bearing cone, and measure the diameter of the sealing surface, then go get the bearing buddy seal system. (repair)
hope it helps
John
cr2k
John
BUT...if you pump them full and hit the road the heat build up and resulting expansion leaves nothing to blow but the rear seal.
CR
cr2k
Bearing buddies are only intended to provide a slight positive pressure when you unload after the long hot trip. This is to eliminate sucking water in the hubs from the quick cooling effect of backing in to the water.
You should still pull and re-pack annually or bi annually at least.
Think about it...If you do not leak grease from the rear seal (as it is supposed to be) how would the new grease get back there? If you are leaking grease form the rear seal you are going to allow water in to the bearings from the back.
