Tafflad
- Oct 23, 2007
- 547
Re: Bearing buddies leaking grease ??
Not really correct ... as long as there is a 'pool' of grease in the bearing buddy, it will keep positive pressure ... and even though some is leaking out the back, no water is getting in (whole purpose of the design)
Now if you let the 'pool' empty ... then water will get in if grease leaks.
I like the new ones with positive visual guide of grease level, via the blue indicator ring.
Bearing buddies are only intended to provide a slight positive pressure when you unload after the long hot trip. This is to eliminate sucking water in the hubs from the quick cooling effect of backing in to the water.
You should still pull and re-pack annually or bi annually at least.
Think about it...If you do not leak grease from the rear seal (as it is supposed to be) how would the new grease get back there? If you are leaking grease form the rear seal you are going to allow water in to the bearings from the back.
