lakeorbay
Thread starter- Joined
- Apr 15, 2009
- 180
I have a severe leak on the bow of my '87 Lund. I've done some preliminary work, but haven't dug in real deep yet. I do know, I need to get under the deck of my bow. The boat is aluminum and has three chambers in the bow. The 1st chamber (I guess where battaries go) has a flat riveted plate, so I couldn't get beneath that one. The 2nd chamber is storage, but it has some sort of bottom that can't be removed without removing the deck. The 3rd chamber, is the livewell. It's riveted in. On either side of it, is foam filled. I've never installed a livewell, so I don't know how to deconstruct one. It has over flows on both sides, so I guess I would have to remove the foam on both sides to remove the plumbing. Not sure how to get the hoses apart when I get to that.
When I get that done, then I will see how bad the damage is. You can't tell a thing from the outside, but it leaks like a clogged rain gutter.
I will get into the BEST fix later. Right now I just want to know how to get to it and how to deconstruct my livewell.
BTW I took out as many screws from the deck as possible, nowI need to remove all of the the bolts and RUSTED nuts from underneath. Quite a few of them.
