few questions for a 1973 Wellcraft 165
chrishayes
Guys, I have been reading for weeks on here sometimes up to 8 hours a day(should be working...thanks). Anyhow, I am starting the resto of this boat. some specs are 1973 Wellcraft 165 airslot with a 150hp mercury outboard with power trim and tilt. I have gutted the interior and removed the motor last night. unfortunatly I dropped the motor on myself(OUCH). I am a 28 year old guy with a herniated disc...To anyone thinking of attempting removing one of these, I reccomend at least 4 people. I will be attempting to take the cap off of her because I need to get to the bow section under the front seats for floor repair and a possible transom redo. so the questions that I have right now are:
How do you get the boat off the trailer and onto jackstands? I saw that John(jcserca) did this but cant figure out how.
How do I remove the 8000 rivets that hold the cap on under the rub rail?
when replacing the stringers on this boat, do I need to grind down the entire hull before reglassing or just the areas that the glass will overlap?
I have a few scrathes in the gel coat on the keel, they arent all the way through the FG but on a few of them I can see the FG. what do I fix this with?
The boat has already been painted before my purchase of her so I dont want to have to do to much to the outside, repair wise, because I have no clue the color that was used and dont want to look like a dalmation:rolleyes: Thank you for supplying me with all this great info and I look forward to seeing all of your projects, along with my own, come to fruition.
Thanks,
Chris
chrishayes
Re: few questions for a 1973 Wellcraft 165
Sorry, there are a few more questions that I have also.
Does anyone know where the fuel tank was located originally on this boat? I would love to have a permanent fuel tank under the splashwell or the floor but cant think of where to put it:confused:
Also, when I am done with the glassing of the floor, what do I paint the deck with? I dont think I want carpet and if I do I will add snaps so I would like the floor to be perty.
When glassing the stringers, so you tie them into the transom? from the factory they arent...
Ayuh,... Drill 'em Out....
Yes...
Very Carefully....It's been covered here,+ in the trailer forum 100s of times...
Btw,... Welcome Aboard...
chrishayes
thanks Bondo, any other suggestions or reading that I could do? Anyone have any answers to the other questions? I will use the search function as much as possilbe as i am sure the newb questions get old...sorry.
