Bedrest2
Thread starter- Joined
- Aug 13, 2008
- 55
First off Hello to all:
I have a project. I have read a lot on F-14's project and seen the pic's, Great
job F-14. I tore mine apart only to find some one had scabbed this before.
The stringers are pieces with cross members solid, I believe this is a week design. The wood is good 1 foot behind the cabin and I would like to tie in at
this point to the back, will a straight cut with support boards on each side
screwed together work or should it be an angle cut?
2nd. Should I peel back the glass and get it wood to wood? or could I leave the
glass, and glass it all together? If I leave the glass I will work the wood so all
is tight, kinda like a step joint. will this work? or should I peel the glass?
Little help please, Thanks in advance.
