Meadfisher
Thread starter- Joined
- Feb 15, 2009
- 182
Re: 1976 tri-hull project
Everything but the sides are painted and there is still a little spot on the nose that needs to be repaired, that wont happen until we replace the cap, yeah man, that is the ticket getting it smoothe, because if not everything will show and youll be able to see it at the primer stage, my lil bro always says when you think you are done sanding w/ p-80, check it 3 more times lol.
Thanks man, we try to do a good job, Oh and not the entire bottom is painted yet, the sides are not prepped or anything yet, the entire bottom from transom to keel have been completed, all that is documented in stages in my photobucket. The plan is to paint the rest in fall when work slows, want to hear something crazy? I landed my little bro a position at the shop where my boat is, well when I said earlier the owner was "cool", well in the process Im certain I secured myself a postion here as-well if I decided I want to go that route, crazy huh? Good chance I may be working there, who knows.
It's all about the prep work and you're doing a great job. I forget, is the rest of the boat already painted? What's the plan for that.
