Meadfisher
Thread starter- Joined
- Feb 15, 2009
- 182
Well in short this is my baby. 1976 tri-hull ( Invader ) I think
I have restored the engine ( with a few up-grades ), I replaced the original outdrive from a VP 270 to a newer 280,the drive in these old pictures is not the one that is currently connectd and those parts are complete for now. Now my issue, there are weak spots on the floor, near the front and the open-bow seem very solid, same can be said for both sides near the engine in the rear, however right in front of the engine there are soft spots on both sides, and the wood appears to be rotted
, I do not have recent pics as of right now, however tomorrow when I begin pulling the old nasty original carpet I will take new ones. Now my brother does fiberglass work so he will be assisting me tomorrow, I know there is not much you can tell me without seeing the issue, but again I will have pictures of the problems tomorrow evening. In the meanwhile you know what my issue is, and here are some older pictures before the new outdrive, and engine rebuild. Anyway I am also replacing the original guages, the only problem is that the old wood frame that held the old guages is cracked and dry rotted, any suggestions? I included a picture of the dash panel, thats what its called I need to make a new 1, know how what should I use? Also can anyone reccommend what material I should use to recover engine cover and side panels? as the seats are new. Thank you in advance
