used venture bass boat
kg5388
I bought a 1986 venture 17' 6" bass boat paid $3000 for it.
I know it sounds like a lot but this boat is solid everywhere and one owner garage kept he is old and needed something smaller.
this boat has 3 new tires with 3 new deepcycle batteries and 1 new deepcycle/starting battery and has a receipt where he had compression checked, new spark plugs and the lower unit serviced.
He uses the same boat mechanic as a friend uses so we called him up and he pulled his records that go back 15 years as long as his shop has been open. Every other year he has had the lower unit serviced, compression checked, spark plugs and impeller changed. The only other repairs has been a rectifier replacement and some kinda hose for block pressure gauge replaced.
Went on a test run and the boat showed 67 on the speedo with 72 on my GPS it has a 150 mariner. He drove the first pass and when I drove I trimmed it in to far and when I hit it all I saw was sky it stood straight up:eek: when we went by my friend said the only thing in the water was the last 2 feet of the hull and the prop.
the only problems with the boat is the cockpit (cockpit is that correct? ) deck as the carpet has come up and you can see where the fiberglass has some minor cracks in it but the deck is solid I'm 6'2" and 280lbs and the floor doesn't sag at all. both casting decks are fiberglass with no wood in the casting decks or hatches. The only wood I can find is in the cockpit floor and the transom looking down in the bilge access I don't see any stringers just the shape of the hull which meets where the top cap comes down to form the cockpit.
the transom doesn't move when lifting the outboard up and down and sounds the same all the way across when I hit it with a rubber mallet.
what do I need to seal the floor with before putting down new carpet or some kind of paint/sand coating?
there are 2 steering cables and the motor will turn easy with the wheel until the boat is moving then it will track straight but is hard to turn is there some way to lube the cables?
also the top three water intake holes have been epoxied up and I asked the seller about it he said they did that when it was new to stop it from sucking air at top speed when on plane. Has anyone heard of this?
I'm also going to extend the front casting deck back as the front is kinda narrow and with the foot control it get kinda crowded up there.
kg5388
Re: used venture bass boat
oh I forgot there is no oil injection and I have a plastic bottle with different ratios on the side and I used 50:1 when I filled it up. is that correct?
also is there anything I need to do all the gas here is 10% ethanol I put in premium.
is sea foam safe to use in the fuel?
Bob_VT
Nice set-up. If the wood is solid and you just want to seal it I would use an epoxy resin then re-carpet.
You have a dual steering system. Is it hard to turn when the boat is on land or at low speeds? I see the motor is on a jack-plate and the higher you run the motor (as long as the water pick up is working safely) the faster you will go and the harder it will turn. When I was running a bassboat I lifted the motor too far and I could not make turns due to the torque and lowered the motor one inch...... I was able to steer but still stiff.
Congratulations on a nice set up!
Bob_VT
Sea foam will not hurt that motor.
No oil injection? (bonus ;) ) I had a mariner Mag II 150 that blew a piston because the plastic oil injection gear stripped....... 1 pint per 6 gallons of gas is a great mix and safe for the motor too.
kg5388
Thanks it turns real easy on land and going slow but gets real stiff at speed.
pulled the cables loose at the motor and cleaned and lubed the shafts and that helped some. also pulled the whale tale off and didn't notice any difference in performance.
epoxy resin on floor do I need to use any cloth mat or just spread the resin on the floor?
Bob_VT
If you are just going to re-carpet over the top..... epoxy resin will work and apply with a paintbrush. Mat would be overkill.
Depending on where you boat and your habits :) I have tilt / trim controls mounted on my steering wheel and a hot foot throttle pedal installed. I was able to keep both hands on the wheel and had better control. I used to fish Lake Champlain in NY/VT and at times the waves would get wild.
dwyork@hotmail.com
Great setup and remember...you can't put a price on fun, looks like you got a great bargain!
tmcalavy
Sweet rig! With that much power, I'd install an air horn so you don't outrun your own sound when you need to get on the horn for whatever reason.
dwyork@hotmail.com
He probably won't even need a horn, because when he breaks the sound barrier his Sonic Boom will be warning enough that he is coming...LOL!
kg5388
NAW don't need a air horn or have to worry about sonic booms after those 2 high speed passes I almost had to clean my shorts.
about 60 mph it begins to chine walk :eek: I think I'll keep it down around 50 thats way fast enough when your used to a 16 ft jon boat with a 20 horse;)
dwyork@hotmail.com
I hear ya man...I stepped into a 16' Skeeter w/ a Merc 115 from a john boat with a 5hp, LOL...I couldn't even imagine jumpin into a boat with 150 horsies.
tmcalavy
You could always boat in the buff, shorts optional...running so fast you're just a blur to others on the lake anyways. Game wardens checking licenses might not like it though.
dwyork@hotmail.com
It would be a bit cold for boating in the buff now, but it does sound a like a great game plan, LOL!
