FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Sweet ! Looks great. I noticed some lights under the T, is that what I'm seeing? if so nice thought, but no rear spreader lights , and maybe a front light! but it still looks great. What did it set you back?
Yes those are led lights under there. I am having some more lights made.LEDs also.Wires are already run.The top installed was $2500. That includes all the led lights installed.Ill put up a pic. of the lights when there done. there alum. cased. realy nice. Ron
I have a 2007 1902wa and wondered if this would work for my boat.Looks good Ron.Do you know how much weight it adds to the boat? Have you had onwater yet to see if boat handles differently? I have the 115 4 stroke.
Went out yesterday.Handles just about the same.Lost about 2mph top speed.
Only weights 56 lbs.New curtins will be installed Monday if the weather holds out.There is no ancher locker on an 1802. Had to Make it.Pulpit is homemadeThere are some other pic. on this forum of the windlass install.Anyone wanting info. on t top maker Just email me for address.Ron
Looks great. Have been considering the same thing myself, need to get the rods out of the way. Have also been considering an arch. Was the top locally made? Did it come with the curtains or did you have to order from another source?
ecrudolph.It was made in Titusville Fl.and the curtins don't come with it.Have
a frind makeing them.Install for curtins is set for Monday If it don't rain.Where do you boat. Florida?. What boat do you have.Check out this site
If your thinking about a top or arch. Ron http://BluePointFabrication.com
I boat in NJ. I have a 2005 1802, so I have been very interested in all the changes you have made to yours. Have considered the pulpit and top when I got the boat also. Ever think of making the cockpit drain overboard instead of into the bilge?
ecru. I did try to change out the drains. To much work and would not work that well.First thing to do is add daul batt. system with onboard charger and a bigger fuse block. You will need this if you add much of anything to your eletc.system.I try to use all LED lights.Ron
Looks great. Let us know how it all works. With all of these projects complete, when will you be installing electric windshield wipers? That is the other thing I have thought about for the 1802.
Wipers came Sat. . Just finished cockpit cover yesterday. Got called back to work Monday so I'm not sure when I'll have time to finish up everything now.
So far every thing works fine.The only bad thing with the t top and curtins is foging of windows. Looking for a good 12 volt fan to stop that. Also looking into a heater. It's 54 inCocoa Fl. today. Ron
Very jealous. You are doing everything I ever wanted to do to my 1802. It is looking great. A small 12 volt portable heater would probably work really well and help reduce the fogging. So you have electric wipers, can't wait to see how th install goes. I just figured you would do it since I want them. I will have to copy your thread as a christmas list for my wife to get me things.
