drewpster
Thread starter- Joined
- Oct 17, 2006
- 2,059
OK folks its time to revisit the rotten transom repair subject. I have to replace the transom of my tri-hull. If I were opting for a complete restore of this boat I would remove the cap and cut the floor out, replace all the wood cores and coat everything. This is not that situation. The floor of this boat is solid. After finding deflection and some stress fracturing I removed the outboard and found wet mushy wood in the transom.
I have researched four pourable composite products, Seacast, Nida-Core and Arjay. First I would appreciate any recommendations you have on the use of Nida-Core or Arjay. Both of these products are more reasonably priced than Seacast. Also I need good advice on how to remove the wood. The chain saw method Seacast recommends looks good but seems a little too easy. They say their product will not bond to wood but how do you get all the wood out using a chain saw and a chisel? Seems fishy.
Capping the boat and simply replacing the wood core using conventional methods is an option. Frankly I do not want to spend that much time on this boat. I am considering removing the outer skin with the cap on and remove the wood. I would then temporarily skin the outside of the transom with waxed ply and pour a new transom in place. Then replace the fiberglass skin and fair. Sound good?:redface:
