Matrex
Thread starter- Joined
- Aug 2, 2008
- 54
Re: Floor, Stringer & Transom Replacement - 85 Doral TRX
Thanks racinrc14,
BTW, I took your advice on fixing the cracks - they are very narrow so I widened them a bit, then drilled the ends to stop further spreading, then filled them in, sanded them etc. Should be better than new.
I am starting to think the other problem I called delamination is not such a big deal. I am thinking it is more a body filler-type application. It looks like dried putty, and you are correct, the problem is only below the motor mount. I knocked off all the loose stuff.
The rear of the boat is not straight across - it sweeps forward slightly (i.e. back corner angles back to splash well - straight across transom to other side splash well - angle up to rear corner) and has similar bottom to top angles. It looks to me like some sort of putty or filler they slathered across the back of the hull to hold the shape of the hull and fill voids when they pressed the transom into place. Does this make sense? You can see what I mean about the shape of the rear wall of the boat by looking aft of the seats/splashwell in this photo:
Thanks for the input - I am a first timer at all of this... guidance/advice appreciated.
Thanks racinrc14,
