Matrex
Thread starter- Joined
- Aug 2, 2008
- 54
I bought my first boat this summer. Rookie mistake #1 (there have been many): I bought it without bringing a boat-savvy friend. Anyway, found out that A) it leaks through the transom and B) the floor was rotten in the back.
Looks like the previous owner knew there were problems. He had peeled back the carpet under the back seat and cut a hole through the fiberglass floor. Put your hand through a it comes out with rotted plywood.
So fine. I like the boat, so want to fix it. I started to tear it apart today. The plywood under the fiberglass floor is completely gone, so I will have to replace it. From the looks of it so far, there are no wooden stringers or foam. It looks like the stringers supporting the floor are molded fiberglass - part of the hull. Am I correct in the assumption then that marine grade plywood, epoxy on the bottom, tabbed into the sides of the hull will be *all* I have to do?
More worrisome is the transom. I know it leaks through the hole that have been drilled - engine mounts, splashwell drain. It looks like someone already tried to fix the fiberglass around the splashwell - but it is not a good job. Water is still seeping through any cracks in the white stuff and around the edges. Any ideas on if that really is a fiberglass "patch" of some sort on the transom (see the white stuff on the transom photos) and suggestions for fixing that up? I have never done anything like this before. Also, how do you seal the engine mounts? Is there a method to that?
Many thanks!
Many thanks!
