evinrude 10hp qd-23
coolguy147
Re: evinrude 10hp qd-23
how do u work a propane torch i have one but how does it work?!??! lol nah im jk. but i do got one but im not stupid theres oil in the exhaust housing u know. anyways ill try the wd-40 some more but i only got like 1 vicegrip so ill try to use a combination ofr things
kjdunne
Your text message style abbreviations and lingo are killing us old guys!!!!! Please write in english!!!! We wish to help you.
coolguy147
nvm=nervermind
idk= i dont know
jk= justkidding
lol= laugh out loud
lmao= laughing my @$$ off
rolf=rolling on the floor laughing
lol i cant really think of much anything more right now.
ok i changed the water pump impeller finally !!!:eek: well i first tried to put pressure on it didnt work. then i took a hammy stuck it between the exhaust housing and gear case. then move the shift rod. bam!!! pop! it came out i was so happy:D ok well im going to go to napa 2moro see if they have the spark plugs. and see if they got any washers for the gear oil change which is on my list. and i going to try to buy the carb rebuild kit this weekend.
any comments questions concerns.!!
freddyray21
So far so good. You are learning and that is important. Remember though that when in Rome do as the Romans do. I understand your posts, but you also have to remember that at not quite, but close to 50 I am still young and happening. ROFLMAO
D.spencer
I have a shift rod connector you can have if you break yours. I am not 100% sure it is the same but, it is off a 1950's model johnson ( mid-something or the other) that was either 25or 35 hp....it was a long time ago...anyhoo, it is yours if you need it and can use it. It is one inch long and 1/4 inch id where the rod goes/and looks to take 1/4 diameter fine thread bolts. I would be tempted to turn the connector where you can get to the side and gently<gently> insert a flat tipped screwdriver in the long split section( it is in the same direction as the shift rod-up and down-not sideways) and gently pry it apart-just a little-while at the same time pushing down on the lower unit-it should slip off. I can post a pic of what I have if you would like to see it. ;)
coolguy147
i like how u used roflmao in the same word lol:D
but thansk for the connector dude but man i nvr broke it lol. i was just remaking the sound effects( really sounded what i said) but it just poped out finally and ya it didnt break lol but im so happy i changed the impeller;)
coolguy147
omg @#$%^ evryword in the whoel entire book some random guy came in and bought 5 of the rebuild kits so im like @#$^%$##. now i have to reorder it and i shouldve went earlier but today is saturday so i could get it. well they asked for a credit card to order it and i dont feel liek useing one but now its going to cost 35 $$$ just to ship it man, im going to try to find a closer dealer this one is to far about 7 miles
coolguy147
ok well i called another dealer and this one is only 4 miles away i been around this area where it is before and they said they can order the rebuild kit. and it will come in around tuesday . my name will be under it so no one can buy it and it only cost 25 $$ how it should be. so im going to stop by a hardware store by my house and getting the washer's possibly changing the oil today if i dont go to the mall soon
wish me luck guy im not that far from victory. oh u guys might know this movie called von ryan express. i watch it last nite and i loved the quote at the end. "if only one gets out its a victory" lol i liked that movie
coolguy147
ok now im really happy. i just called the dealer back and they said they ship a prop somewhere to get it rehubed and they said its around 65$. well i going to drop off the prop when i go pick up rebuild kit so they said its aorund 3 days to get it done. well while i get the new spark plugs change the gear oil and get the rebuild kit install that plus get new gas for the tank and bam let her run like h e double hockey sticks
Sea18Horse
sounds like your on the home stretch! If they don't have the drain plug washers at napa don't sweat it. The dealer with the carb kit will have lots of them. should be about 50 cents apiece. Good luck and keep at it!
.................Todd
coolguy147
thanks todd i look into the washer if i remember when i go tuesday or wednesday or even later =D:D
coolguy147
omg i freakin hate dealers when i order a part and spcifically ask to check and see if theres a float in it i mean it. well i went to the dealer they gonna send my prop to be rehubed but omg y didnt they get the right kit. the stuff came with the gaskets but no float. well they said it will come in sometime i guess i call this saturday see if came in. but man i gotta get some fishing line off of the gear shaft lol:eek:
freddyray21
there are two kits. One with the float and one without. Sounds like they ordered the wrong one.
coolguy147
i ordered brp number was 439071 so idk i think it will come in when my prop comes back in
eavega
You mean gear shaft or the prop shaft?
If you had fishing line on the prop shaft check the gear case for leaks (or just check the gear case oil after your first run in water for signs of water in your oil. Oftentimes the fishing line can cause leaks because it will cut through the seals.
-E
wbeaton
That kit should have a float in it. Don't let them tell you otherwise. It must have been shorted at the factory. I doubt it will come "later" unless they special ordered it once they saw it was missing. That kit is used on several motors from the early 1950's into the 1990's. Nothing special about it.
coolguy147
ok my prop came in!!! its was only 35 $$. im so happy and the carb came in also which was 25 $ with the float. and im going to bike to my other house real quick and empty the gear oil to get the washers man lol. im happy
ok quick question i havent put on this linkage on the carb which opens the butterfly as the magneto advances ive noticed. its weird cause only way i can put it on is when the butterflys r wide open is this normal to do u reinstall the carbs please? i forgot :confused:
Sea18Horse
Good news!
Well, remember your carburator has two butterflies the one near where it bolts to the engine is the throttle butterfly. You should be able to reconnect the linkage to the carb after you reinstall it with the butterfly closed provided that you have the throttle handle in the closed position. Iow the mag plate is rotated all the way clockwise. The butterfly near the throat of the carburator or near the intake air silencer is your choke butterfly. It should be wide open provided you do not have the choke on. If you try to install the throttle linkage with the choke on it could very well interfere. good luck! And remember the faq post regarding carburator overhauling. Everything you need to know is in there.
There is also this article at duckworks magazine.
coolguy147
omg well i pulled the lower unit gear oil and like half of the thing was literally filled with water is started gushing out lol. luckily no metal shards =D. ok well ill ty to install it next time when its all the way closed or off position the magneto. and ya i need to stick my motor back on my atv before i change the gear oil cause like the saw horse is to short for me to stick the bottle up its but lol. ya im working on the carb kit 2omor. omg i got me prop back and i got the washers from the dealer for free and the prop came back from the special place and was painted white lol im so happy1 i didnt even ask for it to be painted
coolguy147
omg i hate changing the gear oil in gear cases god dang i felt like killing myself. freaken i dont feel lik explaining my problems. well my motor is all ready to go i made sure to put the washers on the screws for the gear case. adn ya put cabr rebuild kit on
ok any suggestions?
