fisherman387
Thread starter- Joined
- Aug 24, 2008
- 8
I've been told to put styrofoam under the floor boards to help buoyancy. Is this necessary? I also heard not to use treated wood so the paint will stick is this true?
You can however find treated wood that is not ACQ. The problem is with the ACQ treated wood. I work for lowes and we can get and i think we stock treated wood that is not ACQ. You hear the older guys say "salt treated". Well i think that is kinda how they do it. The ACQ has some kind of chemical that eats away at aluminum. You can also get a paint that you can put on the aluminum that keeps the ACQ wood from eating away at the aluminum, I would not trust it though.
The "C" in ACQ (or MCQ) is for copper. Copper reacts w/ aluminum... check out a galvanic corrosion chart of metals.
I insulated the ACQ and MCQ I used w/ epoxy between it and the aluminum.
Also, they only react when an electrically conductive medium is between them - i.e. ionized water or salt water. After much research, I decided to take my chances w/ the ACQ rather than w/ the expense and trouble of finding marine grade plywood (which uses arsenic as a preservative and therefore doesn't react w/ aluminum).
Also, paint (and resin) sticks just fine to pressure treated wood, as long as it's dry. You won't get either to stick to wet wood (pressure treated or otherwise).
Key note here. The preservative in pressure treated wood is water-born. They don't dry it out after preservation because it'll likely be used in a wet situation (ground contact) anyway, so why bother. Whey you get it at the local lumber yard, it's real heavy because it's still wet.
It can be dried out, but it takes a bunch of time, and you need to keep flipping it over so it doesn't curl up like bacon.
John
the reason pressure treated wood is not used in alum boats is that the chemicals used tot treat the wood causes a galvanic resopnce and the wood actually eats the aluminium !.
the foam is not standard styrofoam......but use a closed cell foam....a 2 part pour in foam is considedrd the standard for floatation....
if you read all of the restoration compleated projects forum.....dj did a great job in there of a tinny and lund also did one......also search "foam" and "deck"
this site if fantastic......there is soo much on just about any question you could ever ask about a boat......
if your goiung to replace the deck on yours....start a thread in the restoration section.......youll get lots of help.....in fact they will walk you right thru it !
cheers
oops
Does this also apply to 'yella wood'? I know it's true for CCA
