888 with blow by-what to do?
Tipsy
Hi all. I have a '75 888 with a problem. My excellent mechanic says I have blow by causing a smoky problem at the back of the engine after running for a bit. It's not an oil leak and it's not the engine coupler. Before I ask him what the next step is I wanted to ask all of you. What is the repair for blow by? Ring job? Complete rebuilt block? STP?
Thanks!
mkast
Re: 888 with blow by-what to do?
It's only thirty-three years old, get it involved in sports so it won't go bad.
Rebuild the engine.
Haut Medoc
Probably time for a a rebuild.....
I'd do a compression test first though.....;)
f_inscreenname
At least rings and if you are doing that you might as well do the rest.
MikDee
Banned
You could try running a can of SeaFoam engine cleaner through it to free up the oil rings, maybe that might help, or, it's rebuild time, or you maybe better off getting a rebuilt 351cu in Ford, and using all your external parts that fit.
Haut Medoc
Careful, the boat will need some modification to fit a 351......;)
