mercury 135 v-6 ,spark advance vs. power
dutch135
1988 Mercury v-6 135hp outboard on a SeaRay Seville. I had the boat in the shop last year for fuel pump problems, and I was told that the Spark Advance had been set ahead, so the shop set it back to factory spec. When i got the boat home, it ran ok, but had no power when compared to before. It would hardly pull a skiier, and top speed had dropped from the high 40's,, to barely cresting 40 mph. I reset that back to where it was, and got my performance back, but I am still curious if this is an indication of another problem. They had done a compression test, which was very good. I have had ignition work done in the past, and feel that with the fuel problem fixed it is running as good as it should. Any thoughts would be appreciated!
dutch135
Re: mercury 135 v-6 ,spark advance vs. power
some other notes, i had been running an aluminum 17pitch prop, but that prop had a spun hub and is now out for repair. i reinstalled the original stainless 19pitch prop, and although not so great for skiing, it will take me over 50 mph. this is a seville 185 bowrider, and with my alum prop i only top ended about 45 or so, with top RPM about 5800, (i watch that carefully). with the stainless at 50mph i am turning about 5200 RPM, so I am toying with repitching my aluminum prop to 18 and hopefully keep my skiing performance, but bringing the RPM's up a little at top end. The motor is finicky, usually needs some throttle to start, but for the most part runs good. :cool:
dutch135
?? no ideas?? somebody has to have something to say! thanks!
JB
Howdy Dutch.<br /><br />Just to let you know that I read all three of your posts.<br /><br />You don't seem to have a problem. I don't have an opinion on what you have done.<br /><br />Good luck. :)
clanton
I would have the timing recheck, you are looking for a burnt piston/s. You need to look at a factory service manual for specs, also this engine may have idle stabilizer shift kit installed as an accessory,and the timing specs are different.
