Weber Carb Kits
thostorey
I have a Volvo AQ 151C and I believe that equals a B23 Volvo engine. It has two Solex 1-bbl carbs. I'd like to replace the carbs and manifold with the Weber conversion kit designed for the B21 Volvo engine. I understand that, except for displacement, the B23 and B21 are identical so the kit manifold should fit on my engine. Please confirm or @#!%$#
Thanks, Tom
Re: Weber Carb Kits
Ayuh,.... Don't Know....
But,.... I Bet those Webers Aren't Marine rated Carbs......
thostorey
Re: Weber Carb Kits
Yep they are, flame arresters and the all. And they are now found on a lot of B21 blocks. I've just found out from the Redline folks that the conversion will work on the B23. Cheers, Tom
