How do you measure shaft length?
Salty Tricks
I have a 1980 Johnson 15hp Model J15RCSD that is immaculate (or close) that I would lke to use as a kicker. Can you tell me what the shaft length is or how I measure it. Thanks, Michael
willamettejeff
Re: How do you measure shaft length?
Ok, so you got me to look at your post. I still don't have a good answer for you though. :rolleyes:
JB
The model number suggests a short (15") shaft.<br /><br />You can confirm by measuring from the bottom surface of the mount (where it sits on the transom) to the AV plate.<br /><br />Good luck. :)
bubbakat
Joe Reeves
In addition to the above, the approximate measurements equal.......<br /><br />15" = Short Shaft<br /><br />20" = Long Shaft<br /><br />25" = Extra Long Shaft
Salty Tricks
15" it is ! Measured to confirm, thanks. A short shaft! Maybe because I'm Irish? <br /><br />now I guess I need an extension kit or a bracket mount. Which?
Salty Tricks
oops!! This is for my BW Montauk and requires a 20". This according to the Whaler geek forum who recommend bolting direct to transom. However which is the least of two evils...a 5" extension kit or a adjustable bracket?
JB
I would go for the bracket, ST.<br /><br />It would allow you to get the lower end out of the water when not in use without the powerhead intruding into the cockpit space.<br /><br />Good luck. :)
martinphantom
Doesn't lowering it more than a couple of inches affect operation of some components?
