Mark42
- Oct 8, 2003
- 9,334
Been messing around with the side and top pannels I cut from foam. I think the side pannels are a little too tall, and the top should be curved (as other members previously suggested). I'd like to cut 3" off the height of the side pannels, and put a 3" bow in the top. This is what it looks like now:
So here is the top. Its leaning against the Mountianeer so you can get a feel for its size. The trailing 6" edge at the bottom needs to be cut off, just havent done it yet. The point at the tip is the center of the V shaped windshield.
So what is a good way to bend this 1.5" thick foam? Its fairly rigid, I can bend it about 2" by hand, but more than that and I'm afraid it might snap. Also, bending like that just bows it in the very center, not evenly.
I can take a razor knife and make 3/4" deep slices on the top side (showing) every 3 inches or so. I'm sure that will let it bow nicely, some strings can be used to hold the bow while two "D" braces are glued on from the underside (one near the front, one near the rear). I could fill the slices with epoxy putty so it will tend to hold its shape and not close up (go flat again) before I get the epoxy and glass on it.
I know it will shrink in width an inch or so from bowing, but not enough to be a problem. I made it plenty wide enough.
Any other ideas or suggestions?
