Crownline 186
Thread starter- Joined
- Jul 17, 2007
- 23
I have a 1993 Mercruiser 3.0 XL that seems to be running on 3 cylinders when first started. After it has run of three or four minutes, it picks up the fourth cylinder. Is this likely a fuel delivery problem or a spark problem? Also, the engine idles fairly smoothly at 1000 rpms, but when I throttle back to about 800 rpms the engine idles very roughly. This is based on the onboard tach, not a test instrument. Should the 3.0 XL idle smoothly at 600 to 800 rpm?
