175 johnson quick help
Ron G
i orderd a manual but they sent the wrong one,any way im changeing the plugs and the parts store ordered me ngk 3133 bpz8hs-10 and the ones in it n<br />ow are ngk br9hs-10 which ones do i need to use?<br />1<br />175 johnson faststrike<br />j175gletr<br />THanks Ron
Ron G
Re: 175 johnson quick help
i forgot its a 1993<br />thanks
OBJ
Ron...the correct plugs are a QL77JC4 or QL16V. Both Champions, set at .030. Stay with the recommended plug.
Ron G
thanks a bunch but everbody around here says to use the ngk whats the diferece?thanks again
Dhadley
That motor's pretty sensative about heat range. I'd sure follow OBJ's advise and stick with what's recommended.<br /><br />And make real sure the fuel is fresh and 87 octane. BTW -- 2 month old fuel isnt fresh. No matter how much new fuel you dump on top of it.
Dhadley
What brand motor does "everybody around here" have?
Ron G
Thanks d the gas is fresh i run a tank out about every 2 weeks i was putting 93 oct in it but i read all this postings here and everbody says 87 is fine so ill go back and put the recomend plugs back in it.everbody here mostly runs mercs and hammerssome rudes.thanks again
Dhadley
93 octane and KGB....errr..NGK in a Rude is a dangerous combo. NGK's belong in Yammies and Mercs. Champions belong in E/J's.
Ron G
Thanks a million ill change them out.one more ? which of the champions would be better the ql77jc4 or the ql16v? thanks again
angus63
1993 175hp v6 60° eagle looper should have QL78YC Champions gapped @ 0.030" I believe. 1993 was the year they changed from the QL77JC4's. Correct??
Dhadley
You can use either the QL78YC's or the QL77JC4's. I prefer the slightly cooler 77's in mine.
Ron G
thanks a bunch guys it is on a bass boat so ill probaly try both.
Ron G
been real busy at work.been running regular fuel the past 3 weeks.took out the ngks and installed the ql77jc4 i have a small tournment tonight tonight so ill see how they do the gap on the ngk was way over 30 also ive been watching my rpms with gear and a partner im only running around 5100 or 5200 rpms dont know whats happeng???also trim gauge quit again checked for power on gauge no power but the purple wire is sliced into the power wire going to the water pump gauge it works fine?ill let ya know how the sparkplugs do tonight and the rpms thanks.
muchco
While your talking about plug gaps. I have a 1987 Evinrude XP150. I have a 1988 OMC service manual and it states to use QL77JC4 plugs and set the gap at .040". I see that on this thread that everyone is recommending .030" gap. Would someone be able to tell me the plug gap I should be using on my 1987 XP150, and are the QL77JC4's the correct plugs. Was there a recommended plug change from 87 to 88 on the XP/GT 150 OMC engine? Thanks for the consideration of my question.
gsbodine
Originally posted by muchco:<br /> While your talking about plug gaps. I have a 1987 Evinrude XP150. I have a 1988 OMC service manual and it states to use QL77JC4 plugs and set the gap at .040". I see that on this thread that everyone is recommending .030" gap. Would someone be able to tell me the plug gap I should be using on my 1987 XP150, and are the QL77JC4's the correct plugs. Was there a recommended plug change from 87 to 88 on the XP/GT 150 OMC engine? Thanks for the consideration of my question.
I think that plug is fine as I run them in my '78 Johnny 150 as recommended. Most of the J/E's I've seen of this size do, but I suppose that's a better question for Dhadley. I think I read on here before that the larger gaps work better if you do a lot of idling and not as much WOT cruising, but hopefully one of the gurus will come and confirm or deny that for you. ;)
muchco
Thanks for the response, I will see if Dhadley or one of the other J/E gurus have any input.
clanton
The correct plug and gap can be found in the current Genuine Parts Dealer Catalog, also see service bulletin 2292R1 which ref this catalog. Dealer should have these items. The 60 degree engines are also sensative to sparkplug wire type.
OBJ
Checking the current P&A BRP catalog, the current recommended plug for your engine is the Champion QL78YC set at .030. The associated bulletin does not recommend any alternates.
muchco
Thanks for the response. I don't have access to a BRP catalog. Any parts book I do have access to (eg. Champion) list the QL16V as the recommended plug. Marine mechanics up here suggest just using the QL77JC4's. Is the QL78YC a surface gap plug like the QL16V? I have been told that if any amount of idling is done to stay away from the surface gap plugs and use a standard plug of similar heat range. (eg. QL77JC4) It's just confusing that the 1988 OMC service manual I have recommends QL77JC4's with .040 gap. Was there that big of a change from 87 to 88? Just curious.
clanton
The engine should run fine with the QL77Jc4s gapped at .040 0r .030. The engine may idle a little smoother with the .030 gap. The QL78YC is a little hotter plug to burn clean at idle for a smoother idle. The GT/XP 150 should burn a QL77JC4 to the color of toast.
