Driveshaft seal above or below impellor??
fishnhunt
Is your driveshaft seal located above OR below your water impellor housing??? Going to change impellor and drive shaft seal out and cant locate it! Thanks
*1996 70hp Force
cordell
Re: Driveshaft seal above or below impellor??
If it is what I am thinking it goes up top on the drive shaft. The little metal cup sits up and the rubber slides into it. You should see the seal is tapered to fit in the metal cup.
cordell
Dave K.
possible the seal & cuppling is stuck to the spline up inside the leg. they sit on top of the drive shaft - cuppling first then seal on top.
jerryjerry05
Drive shaft seal for the lower unit is located under the waterpump housing. Jerry
