Day Dreamer
Thread starter- Joined
- May 3, 2008
- 9
I guess it's one of those things that just happen. One day you are just joe blo out there working for a living and you buy an old boat because you thought it would be fun for the family. It's just an old boat anyway.....right.....what could go bad on a boat?........they'd last forever.....right?
Well, when I gave that gentleman a check for my 1980 Aristocraft 9teen, I wasn't buying a boat, I was buying an education. I've learned so much since then, it's amazing. And I continue to learn and don't see an end in sight.
Now, I've learned that I have the dreaded water in hull/foam disease. Not horribly, but it's there. Pretty much resting in the bottom of the hull/foam. The water is clear and the foam actually looks fine albiet moist. I opened up a hole under the carpet and opened up a 3" hole that was covered by a previous owner.
I've read all of the stuff that I could fine on this subject and have determined that an attempt at draining it is pretty much a waste of time.
If you don't know, an Aristocraft was the first boat to be all fiberglass. They didn't use wood in the hull. My thought is to cut out two panels in the floor that happens to rest under carpet in order to clean as much foam out as I can reach. Since there are no wood stringers or formers, do you think that I can get away with this as a solution. I would make every attempt to allow the remaining foam dry before replacing the voided areas with fresh foam.
At that point, the panels should be able to be replaced and new carpet put over the area and it would be covered up nicely.
Any thoughts? Like I said, I'm new to much of this, so all opinions (pos or neg) are welcomed. I really like this boat and would like to keep it for a good while and keep making it better and better little by little.
Let the learning continue.
