pics of my boat project
brian3127
Re: pics of my boat project
when glassing the stringer with 1708 can i put 2 layers on in the same day or should i let the 1st layer cure 24 hours. or once the heat is gone can i put another layer on it
i will be fixing the hole tomorrow
erikgreen
Ideally, put the 2nd layer on before the first one cures... that way they form a single piece of fiberglass.
brian3127
well that should be fun i will have to find some slow acting hardener.
ondarvr
You should be fine doing both at the same time, if it's hot out just wait for a cooler time of day.
brian3127
Re: pics of my boat project stinger work now
ok im working on my stinger. the old one i used as a template didnt really fit the contours of the boat. they left the bottom of the stringer sguare. should that have an angle on both side to fit into the groove (keel?) at the bottom of the boat. or could i just fill in the groove with peanut butter and set the stringer on that. thats how it was done origanally. would it be better if i made it fit in the groove and just use pl premiun to bed it? i have a bunch of saw dust from cutting all the plywood and i can get more from my buddies house he has a wood shop. could i use that to make the peanutbutter?
erikgreen
Whew, buncha questions here.
First, you don't ideally want the stringer to touch the fiberglass in the bottom of your boat. If the wood touches everywhere evenly (impossible to do) it'd be fine, but most likely you'll end up touching in places and not in others. That creates places where the hull can flex more around spots where it can't flex at all, which are called hard spots and cause cracking and hull failure.
So, use either PL or peanut butter to bed the stringers, to make sure the force is transferred evenly from hull to stringers. Some people use instead a thin strip of pink foam to hold the stringer away from the hull while they glass it in... the glass transfers the load hull->stringer very evenly.
You can use sawdust with resin to make peanut butter. Just make sure it's dry, clean sawdust with no oil in it. You can also buy a can of filler like wood flour to make it, or use dust from grinding fiberglass if it's clean (white).
The groove is indeed the keel. You can either fit the stringer in it or fill with peanut butter (not PL) and set the stringer on it, your choice. The keel doesn't flex, and filling it would make it very strong, but fairly heavy, and use a lot of resin. Up to you.
Erik
brian3127
thanks ericgreen i think i will go the route of useing peanut butter and fill the keel. then set the string in it. it will make it easier then tring to gring the wood to fit the keel. plus i like the sound of makeing the keel stronger by filling it. thanks for the advice eric.
brian3127
well im going to put the stringer in tomorrow i will have pics of my work
brian3127
well there was a good chance of rain today so i didnt put the stringer in today
redfury
Don't feel too bad, we're getting snow again!
brian3127
i dont think i will be working on the boat today it is cold. yesterday it was 70 out this morning 40 wind at 18sw. hope it warms up some. yeah they are calling for snow here monday. i wish it would make up its mind.
brian3127
well it was a good time it get sick. the weather here is cold and rainy this past week. it is sunny now but the radar is showinga big storm coming over the lake so i dont think i will work on it today either. hopefully tomorrow.
oops!
waiting on the weather to fix a boat is like watching paint dry.....
brian3127
yeah tel me about it opps. havent worked on it for a week.
brian3127
well i put the stringer in the boat today. i should have pics either today or tomorrow. i added a cross members to the stringer becasue i wanted something to screw the deck to. at the 8 foot mark. considering i cant find plywood over 8ft lenght.
brian3127
Re: pics of my boat project more pic
news stringer in place with cross member
i386
That looks really good. Good job.:)
hypnotist
Brian,
what type of material did you make "stringer" out of? The stringer in my boat botton is also rotted out and in need of replacement. Also did you glass in the stringer ? And the foam was it brittle, the foam in my boat botton is brittle and not as large an area as yours. Im thinking keeping it as it is after allowing it to dry.
Coors
Brian,
It will never dry. Never. Never ever, even.
Pull it out.
brian3127
yeah what coors said it wont dry
i have been doing a bunch of grinding over the week and i will have pic tomorrow
im going to start glassing tomorrow
i made the stringer out of plywood 2 peices of 3/4 glued together with gorilla glue
