Will 50hp Johnson lower unit fit 65hp
Tonyc54
I would like to know if anyone knows if a 1973 50hp johnson mod. #50ESL-73R lower unit will fit a 1973 65hp johnson mod. #65ESL-73R. Thank you.
tashasdaddy
Re: Will 50hp Johnson lower unit fit 65hp
50 was a 2 cylinder, 65 3 cylinder, doubt it, but not sure. check out the part numbers at BRP-evinrude.com literature, engine diagrams
Tonyc54
Thank you for the reply. I checked out the web site you suggested. I found that the complete gear case assy. part #'s are different, but the gear case and bearing assy. #'s are the same. So I believe that the 50hp should fit the 65hp. I hope it fits I can get one at a resonable price. Any thoughts? Thanks again for your help. Tonyc54:)
rudedude
I know a 50hp L/U fits up to and includeing a 60 HP. Not sure about the 65HP.
I'am guessing you dont have access to both units , if your thinking about buying one or the other can you have the seller check the bolt patterns and such.
Tonyc54
Hi, I can e-mail the person and ask. I'll see what he says. Thank you
rudedude
Have him put a tape to it, center to center of bolt holes, overall lenth and the shaft.
Chinewalker
No, it will not work. Driveshaft splines are different...
- Scott
Tonyc54
Hi, Do you think it would be possible to swap the drive shafts? Thanks
jwilkey84
There is one on ebay as we speak. Ther is 2 days left on the auction, the buy it now price is set at $199. That is a good price in terms of what I have been watching them bring on ebay. You might check it out. Just go to ebay and type in 65 lower unit
Tonyc54
Hi, I'll check it out. Thank you
