2006 Ford 6-spd tranny - good or bad?
KaGee
Looking at 2006 Explorer with the 3 valve 4.6 V8 and 6 speed auto-trans 4x4.
The engine has some history behind it in other vehicles and seems solid. The tranny was new in 2006. I like the engine for added power for towing my boat and from what I read, gets the same fuel mileage as the V6. It only comes with the 6 spd tranny.
Any Ford guys with any pro or con to say about this new transmission? :confused:
mrfixitman40
Re: 2006 Ford 6-spd tranny - good or bad?
Kagee I work at a ford dealer and we haven't seen anything with the six speed like the five iin the explorer so far they have been very dependable just checked and no tsb's for problems either
KaGee
Thanks! That's the kind of inside info I was looking for.
mrfixitman40
any other ?'s feel free to ask if you are looking at used get me a vin and i will run it and see if it has anything unusual going on
wildspeed
I have a 07 Exp EL with the 6 speed, so far so good, but didn't pull anything yet with it
rentalguy1
If it's a Ford automatic tranny, then it's a time bomb. That is, unless it's a C5 or an AOD. They have been built with less than stellar quality since the A4LD came out.
I'm not a Ford Tech, but I have been a Ford owner for years, and I most likely will always be one.
QuadManiac
Hey MrFixit.. I've got an 02' 4.6 Exp, tow pkg, with the dreaded stock auto tranny. When I go to replace it, as I will have to do soon cuz the shifting is gettin real bad, is the 6 speed drop in replaceable? I'd love to go to a different tranny and get rid of the pervasive problems of that 'fuzzy logic' POS that's in there now.
Tail_Gunner
Ohh Plzz you old redneck.......:D
mrfixitman40
you would have to change wiring harness and processer in order to do a drop in depending on your shifting concern they updated the solonoid pack in the trans (only a half hour job) which corrected most of the problems
QuadManiac
With 80,000 miles and some towing, will the solenoid pack fix my problem, or has driving with the hard and stuttering shifts for a couple of years damaged it now beyond repair?
KaGee
Well, I pulled the trigger on the 06 Explorer. Hope it was the right decision.
As for you Quad, the Ford Stutter is common . On the Escape I just traded, I had 98000 on it. I deveolped the stutter twice and cured both times by a fluid change and an additive put in... sorry, I forget what it's called, but it was a Ford product.
mrfixitman40
is it just a hard shift or is there slipping if it is just a hard shift chances are the soloniod pack and fluid flush would fix it
mrfixitman40
Kagee pm me the vin and i will check it for recalls and processor updates plus see any work that has been done to it
mrfixitman40
i sent you a copy of the oasis report everything looks like it is good to go
KaGee
Thanks! That's great!
QuadManiac
Sometimes normal, sometimes a jarring, hard shift, sometimes a big stutter... not like slipping, but it sets up a big oscillation that wont go away until i lift my foot off the gas.
Feels like one clutch is trying to engage before the other disengages... but that's just a gut feeling.
mrfixitman40
what speeds does this happen mostly is it up around 45-50
QuadManiac
No. lower speeds and not under full load. Most typical when Im just cruising along. If I get on it, everything seems to work well.
Typically, 1st - 2nd is (i think, but might be 2nd to 3rd) is the one that causes the stuttering or oscillation - it can be very violent, other gears can be nice, or sometimes very hard (solid) shifting... and the locking converter can be very clunky sounding. All of these symptoms are variable... when the engine and tranny are cold, never happens. When it is hot, it seems to be dependent on the phase of the moon, or something... i have'nt been able to determine any corrolating events that cause it to happen, and I'm an engineer, so I look for those things!
Once in gear, everything is just fine, no slipping or any other evidence of problems. Only occurs during shifting, and typically on upshifts only.
dolluper
Ford >>Carp ...weak pumps, add a vane usually cures, bad solinoids caused by carpy wiring
