tjt1980
Thread starter- Joined
- Jul 9, 2007
- 21
Several weeks ago, I was cruising accross the lake, and all of the sudden the siren went off and the "no oil" light came on. I slowed to a halt and by the time I started investigating, the siren stopped. When I looked down at the guage, the light stayed aluminated for several more seconds, then went out. I figured everything was cool, so I hit the throttle and proceeded. About 30 minutes later, the same thing happened. It has been happening every 15 minutes of operation or so. It only happens when i'm at speed. Hitting wakes does not seem to make a difference. When I slow down, or stop, the siren stops and the light goes out.
I inspected everything from the VRO reservoir to the entry point to the motor. Everything looks good. No leaks, no kinks, no cracks in the line where air could get in, and the float sensor in the reservoir is operating perfectly.
The only thing I can see that could possibly be an issue is on top of the reservoir there are three entry points. The place where you put oil in, the place where the float sensor mounts, and a third place that has a capped off tube coming out of it. The rubber piece that is capping the tube in the third spot is dry rotted. I wrapped it in some electric tape and went on another spin. The problem still occurred.
Question #1: Am I doing damage to the motor every time that alarm goes off? If so, how much?
Question #2: Does anyone have any idea what I can do to troubleshoot this thing? I think it is the oil pump or the sensor on the pump, but I don't know how to prove it.
Thanks so much for all your help. This forum is awesome!
Oh yeah, my motor is a 2000 Johnson 90hp Outboard mounted on a 1999 Glastron GS-160. I do not have a manual for the motor or the boat.
