FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Well Finally got around to it. Started with the sender. Pulled it out and hooked it up to the voltmeter. There was a big spike in ohms around the halfway mark so I put in a new sender and all is good..
Luke
Wow...you do all that through that little 5 inch port in the back? lol I used to look in there and pray I never had to work on the tank when I had my 1802. I did epoxy a "shoot through the hull" transducer back there but I shudder to think of replacing that sending unit.
Luke
Luke -- Yesterday I discovered I had the opposite problem you had, guage always reads empty and I know there is fuel in there (1995 2002W/A). I think my sending unit is Kaaaaput. I would suspect that the sending units are all the same in these Trophys. What make, model, and where did you get the sending unit, how much $$$$$$$$$$$$$????? I was going to install a new Lowrance LMF-400 fuel flow/quantity guage and sensors. I wanted to know what the factory guage read as a beginning base line for the new install. Now I gotta put that project off until the send problem is resolved.
