The motor has been running great this spring, have put roughly 30 gals. of fuel through it . I was out the other day, completed a 20 mile crossing of the bay, when I came off plane the engine stalled. Started fine and idled fine, got back up on plain and ran for another five minute then gradually lost power over 30 seconds, I brought the boat off plain, the engine idled fine. Then I could start out again and go another 1/2 mile then I would loose power again.This happened a few times, then the engine ran fine for 40 minutes, when I got close to shore I let off on the throttle and tried to reapply throttle and had loss of power again.
The motor was running at 120f and 25psi water pressure. I tried switching fuel tank and line and also tried pumping the gas line during power loss with no affect. I have cleaned the fuel filter on the motor, drained carbs, the plugs look the same.
The power loss it very smooth and gradual no vibration at all.
Where should I start, any help would be greatly appreciated.
Thanks....
Thanks....
