Re: What RPM should my engine run @ WOT?
The prop looks brand new, not sure what pitch it is. I havent done a compression check. Engine idles smooth, and has excellent power, seems to be in perfect running order. I guess I could take it to a shop and have it checked out. Got an issue with the blower that I am having trouble diagnosing anyway. It runs at a low speed constantly unless I pull the fuse. If I turn it to the on position, it runs at a faster (normal?) speed. but in the off position it just runs, slowly. I think it is in the switch. The switch is a 3 position switch. To the left, the blower comes on, to the right, the bilge pump and in the middle it is supposed to be off. Anybody know where I can find a replacement switch for an 82 Glastron Sv-191?
