Restoring and Polishing Gelcoat
johnrmclean
I have a 94 BAJA which has purple and black waving stripes running the hull. Last yerar it was fine but over the past winter the colors, particularly the black, seem to have faded, fogged or slighlty discolored and i can't get them back even after I waxed the hull. At the waterline in particular the fading seems to have left a line below where it crosses through the black stripe.
I used 3M's combo wax and polish for mildly oxidized finishes with a power polisher and it seems to give me gloss but the dark colors still seem faded or slightly cloudy and I see some swirl marks. No problems on the white hull areas. Where do I go from here? Should I go more abrasive on the color or less? What products should I use? :mad:
Windykid
Re: Restoring and Polishing Gelcoat
Some of the other guys have had luck with comet and a scratch pad. Then wax and polish. If you do a search here for restore finish you will get a lot of good ideas.
gcboat
First off - are these decals or paint? If decals then you just might be SOL. The paint ( gel coat ) will come back nicely with the right materials and tools.
And no, I wouldn't go with anything more abrasive - if they are decals.
Look through here : http://www.boatus.com/boattech/casey/01.htm
