Hole in my Tracker
Gordon A
I have a hole, below the water line at the rear of my aluminum tracker boat. This was where the water inlet for the livewell used to be. I have removed the livewell fro the boat and I now need to patch this hole up, the hole is about 1 inch in diameter.
Any suggetions would be welcome.
Cheers Gordon
Re: Hole in my Tracker
You can install a garboard drain and plug, and never remove the plug. You could rivet a plate across it. Put some Marine-tex on the plate to seal it.
Or put a Thru-hull back in it,+ Cap it off on the inside.......
Silvertip
Do it right -- have it welded.
jddenham
You might want it later on so check out all temporary options before welding.
Windykid
I dont want to sound like an a@@ but do it rite. Have it welded by a pro. You wont be thinking about a leak after that. If you do a temp job it could come back to haunt you. If you have it welded and change your mind you can always go to the local hardware store and buy a hole saw.
Silver and Windy, What part of a garboard drain, a thru hull fitting or a riveted plate qualifies as a "not right" repair? I do not appreciate your arrogance.
Windykid
Chris the idea is to give a person options, which you seam to think yours may be the only one. Since the hull is aluminum and a welded patch is permanent there would never be a worry. Your way may work just as good but its a matter of opinion.
Talk about arrogance.
