Re: transom seal
If what you have is a rubber rope about 3/4" in diameter. just glue it down in the groove and cut the so it's just a little long and cut it square and glue the ends together, I use bellows adhesive to hold it in the groove and between the ends. Put the joint at the top, which will normally be out of the water anyway.
