Evinrude 115 not starting
bowrider
Re: Evinrude 115 not starting
Where is this trim tab located?
ezeke
Just above and to the rear of the propeller. It deflects the propeller driven water and helps to compensate for engine torque. Loosen the bolt in the center and you can turn it . There are small raised adjustment marks so you can set it in increments.
If you have a factory service manual, it is described on the last page of the "Gearcase" section, or section 6.
bowrider
Someone recomends that ^^ manual?
