transducer instalation................
bhm25
looking for some info on how to install a smaller stem transducer in a holes that is bigger form old one. whats the process and whats the best technique ???? thanks in advance for any info .
tashasdaddy
Re: transducer instalation................
what type boat fiberglass, aluminum?
bhm25
forgot some info....fiberglass foam core hull
Epoxy the Old Hole Closed,+ Install the New, Smaller 1.........
BHM, In a cored hull is is advisible to drill a hole larger than the object to be installed, fill the hole with fiberglass, and then drill the new fiberglass to install the unit. This precludes any water from getting to the core material. In your case, you should be able to fill the hole(Marine Tex or other epoxy putty product), and then redrill for the smaller transducer.
i386
All good advice. Don't be tempted to use Silicone. It won't last.
bhm25
do you guys recomend 2 or 3 small layers of cloth on bottom side ?
as of now i i filled the hole with west system and 406
ManOfwar690
ok even beter is cavasill and resin and a drop or 2 of hardner just a drop and u can mix some white pigment for a no show fill and water tight for life
