Is there a formula to calculate speed from hp and weight?
Mark42
Seems to me that there was a graph that used to be posted often that would give speed based on hull configuration, weight and hp.
Lets say I have a 18ft deep v weighing around 2800 lbs, and I want top speed to be 35mph from an outboard motor, how much hp will it take?
JB
Re: Is there a formula to calculate speed from hp and weight?
Well, there is a basic formula that has worked well for me.
WOT= (square root of HP/weight) x BF (bottom factor)
Bottom factors range from about 150 for a deep vee to about 225 for a jon flat bottom. You just have to guess where yours falls. The example below uses 150 for BF.
Do some high school algebra to solve for HP for a selected WOT.
Divide both sides by BF and cancel.
WOT/BF= square root of hp/weight
Square both sides and cancel.
WOT/BF squared= hp/weight
Multiplyboth sides by weight and cancel.
weight x (WOT/BF squared)=HP
Insert knowns:
HP=2800 x (35/150 squared)
=2800 x (.2333 squared)
=2800 x .0544 = 152HP
If your BF is more like 200 the solution is 85.75HP.
Now you need to determine the max HP recommendation for your boat.
Good luck. :)
Ayuh,...... I was never a very good Mathamagician,.......
JB Lost me at "me."
Good Link,..... Deserves a save......
