sealing bolt holes and thruhull holes
Thumpbass
Is it common practice or a good idea to seal outboard mounting bolt holes and thru-hull fittings with something like resin or Gluvit before installing and siliconing? seems like it would be a good idea but this newbie knows it's better to ask first.
JUSTINTIME
Re: sealing bolt holes and thruhull holes
yes
if u drill a hole u need to seal the wood before u install the bolts or mounts with 5200
get a marine expoxy and seal the open wood, then intall parts with 5200
biggy boy
The 5200 is made by 3M and is good below and above the water line. It comes in a squeeze tube or in a caulking gun tube. Don't use silicone it does not adhere well and eventually will let water in.
Make sure that the epoxy is dry before using the 3M 5200 .
Glen
Bob_VT
Use 5200 0r 4200 DO NOT use silicone - it will leak. Do Not use gluvit or it will NEVER be able to be taken apart!
strizzy
I would use 4200, you will thank yourself if you ever need to remove the motor.
dhatcher
yeah 5200 is kinda unforgiving in that resolve lol once its there, its there......
Got to love the stuff though
JUSTINTIME
5200 is used on everything but outboard mounting bolts, below water line
they do sell a 5200 un-bonding gel
other people just use wire to cut it out
Thumpbass
I guess I was talking more about using a hard resin type product (and letting it fully cure) before adding the softer bolt sealant (5200, 4200) and hardware. My thought was if you used a product like Gluvit to seal the actual wood then if water does make it's way into the bolt hole then at least the water can't be absorbed into the wood.
Bob_VT
The bolt holes should not have that much room. once you put 4200 or 5200 on the bolt the wood will be sealed.
Take a bolt coat it with 4200 or 5200 and run it into the hole and spin the bolt. You will get more than enough to seal the wood.
