Weight of 1980 4-cyl 80hp?
Status
Not open for further replies.
dctucker
Anyone have any idea what the weight of this motor is? My guess is around 300 pounds, but I'd like to know the actual weight.
I hate to say it, but I'm thinking of repowering and I'm curious as to the weight of this outboard vs. any potential replacement.
I love this motor when it's running, but it's just too unreliable for my needs, providing safety, support and coaching for disabled sailors training to try to win a Paralympic medal. I'm tired of throwing time at it, and good money after bad. Not to mention that $30/day in fuel is tiresome, knowing that a new tech motor will be notably more efficient.
I could spend time and money on replacing the wiring harness and electrics, or spend time trying to get a manufacturer to donate a comparable size motor to the cause... If I succeed at that, the motor will be available for one of you to love and care for!
Bob_VT
Re: Weight of 1980 4-cyl 80hp?
I imagine you are looking towards a 4 stroke. Try to obtain the difference in weight and sit it on the motor in the water. A new 90 hp or 75 hp Mercury 4 stroke is 399 dry. Got any friends who weigh 148 lbs? I find that the pretty ones in string bikini's work the best! Have them sit atop of your present motor (not under power for safety).8)
dctucker
The boat is a 5.4 meter Avon RIB (18'), which weighs about 700#, so a lighter motor is preferable to me... The boat is all about power to weight ratio 8) I agree that 4 strokes are too heavy. I want a new tech, injected 2-stroke. I'm resigned to the fact that any new motor will be heavier, it's just a question of how much. Heck, an 90 hp Opti is 375#. Merc is not competitive by this standard.
90 hp E-TEC is 326#, Tohatsu TLDI is 315#. Those are at the top of my list. I've been in touch with both manufacturers, and I'm optimistic that one of them will come through with a sponsorship for the disabled sailors.
Yamaha seems to be the lightest 4 stroke at 369#, then Honda @384#. The Merc 4-stroke is the heaviest of motor in this class at 399#! But why is the 2-stroke Merc Opti heavier than any 4 stroke??
148# in a string bikini? If I were to have that on the boat, my wife would have me living aboard!
cougar1985
90 e-tec,way better than the 4 stoke slugs
SeaKaye12
Good Question dc...
I have esentially the same engine that you have...and I also wonder exactly where the extra weight is in the new ones. I know that they have oil injector systems and fuel injection and some fancy electronics...but I can't imagine much of the extra weight being in those areas...
Maybe someone here will give us the answer.
Thanks for reading, Chuck
A DI 2 cycle motor will be a bit less weight than a 4 cycle motor, but not much. Your current motor will be at least 1/3 less weight than either of those.
Gee, Merc made a 3 cylinder 90HP 2 cycle outboard for a while. They are only avail used, but at least you would move up a couple of decades.
Status
