arks
- Nov 7, 2002
- 1,966
What's involved other than running it to flush all the water out? Should I run antifreeze thru it? Should I drain the gas tank or add stabilizer to it (it's a GTI with a seperate oil tank)? It will be under cover, but outside in below freezing temps. I will remove the battery.<br /><br />BTW- it's got a new jet pump and a year-old engine just serviced last month, so I'm not planning to do any other service until spring.
