Anybody have any idea where I can find a diagram of the fuse block of a 1979 GMC Vandura van? I imagine some previous and later years and probably trucks would be the same if I could find any close to 1979 also.
I dont have the owners manual.
Thanks
Announcement
Collapse
No announcement yet.
1979 GMC van FUSE BLOCK diagram????
Collapse
X
Tags: None
Re: 1979 GMC van FUSE BLOCK diagram????
Going from memory here so bare with me....on the right side lower IP panel for guages there is a relay....behind on the guage cover that is ,,,it's used not to screw guages when starting.....could be different location it was a while ago I worked on one of these LOL's ...so far your tracking down is paying off ...so don't give up your doing good
Just got done checking the fuse box out and I'm starting to think all the non-working things are not related. Every test I did in the fuse box checked out ok.
And I found out the blower motor connector on the motor itself under the hood was off. Plugged in back on and blower is working.
Guess I'll start looking elsewhere besides the fusebox.
Leave a comment:
It is the factory AM-FM radio. I haven't seen where any wiring has been cut into or spliced. Everything I have seen so far looks normal.
Not working:
Oil pressure, temperature, and voltmeter gauges
Heater blower motor
Radio....no power
Cruise
That's what I know of that is not working.
Working: Fuel gauge, Dome light (with both headlight switch knob and door jamb switches), All exterior and driving lights (stop, tail, turn etc), Inst. Panel lights, Wipers, ......haven't tested horn.
I pulled all fuses from fuse block...all were good.
My next step is to put a voltmeter into fuse terminals in fuse block for connections for gauges, blower motor, and radio fuses to see if they are getting power from the fuse block.....then jump the blower motor connections to see if the blower motor itself is working.
EDIT: Horn also works
Leave a comment:
Give us a list of whats not working....me thinks someone did some wire butchery....no power to guages cut spliced wire to add something or an in line fuse.....radio probably....not stock one eh
Leave a comment:
Originally posted by Wishiniwuzfishin View PostMy key switch is on the dash, not the steering column. I think it's OEM but can't say 100%
Yes I tried the ACC position also...no change.
Guessing the company that converted the chassis to a motor home musta done that. Pretty much every GM car and truck from that era had the same Saginaw steering column that worked like I described.
Still could have issues with your switch...
Leave a comment:
Leave a comment:
Originally posted by Wishiniwuzfishin View PostI know where to put the key in.I assume the contacts on it are what you are talking about.
Could bad contacts be causing my problems?
I guess I should put a voltmeter on the fuse box and see if I'm getting power to the individual circuits that aren't working. That would be easier than trying to check the key switch.
Leave a comment:
Leave a comment:
Originally posted by Wishiniwuzfishin View Postdome light works with door jamb switch...... I/P lights work........also forgot radio and cruise don't work.
Couldn't read most labels on fuse block but I pulled all of them and all were good.
I guess it's possible that everything that doesn't work is not related.....just don't work
Guess it wouldn't be unusual for blower motor, cruise, and radio to not work.......but temp, oil pressure and voltmeter all not working seemed odd.
Going to try and jump blower motor tomorrow....not really concerned with radio or cruise.......but would like to get gauges working.
Any more ideas?
What about the big honking 33 year old ignition switch you mentioned before? It's not out of the realm of possibility that the contacts inside are shot. You know where it is, right?
Leave a comment:
The diagram should not be too far off of this http://www.elcaminocentral.com/articles/wiring/811.gif
Try google images.
Leave a comment:
Any more ideas?
Leave a comment:
If dome light + IP lights don't work it's a sure sign the door switch not grounding or is faulty....be very carefull if you remove them 2 wires on back can fall off infin you don't hold your head right LOL's ..best to disconnect the battery....if wires fall off your going to be removing kick plates and more to get at them a pain....just look where the switch installs in door frame if rusty good chance it's not grounding and the problem....clean up and reinstall
One other place to check if multiable electrics not working is the fuseable link by the starters main bolt there should be 2 located there on heavy red wires
Leave a comment:
Thanks for the replies guys. Actually the vehicle is a class C 24ft motorhome, built on a GMC 1 ton Vandura chassis. From the front seats forward it is basically the same as a regular 1 ton van.
Previous owner told me about the gauges not working......I discovered the blower motor issue while driving it home.
I was just looking for the easiest way to troubleshoot. Might have to get in there under the dash with a voltmeter.... and I'll check out the dome lights today.
Any thing else I might look for? I read something online.........if I understood it right.......that some parts of the fuse block get there power thru the ignition switch. Issues with it might be causing the problem. The key switch works fine for starting it up and haven't noticed anything except what I mentioned.
Fuel gauge definetely works....put some gas in it.....needle moved up.......drove it home....needle moved down.
Not sure about IP lights. Drove it home in daylight so I didn't use headlights.
Leave a comment:
iboats Boating Forum Directory
Over 100,000 Questions & Answers
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats (250+ Manufacturers)
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Leave a comment:
