coolguy147
- Jul 14, 2008
- 2,817
well i finally found a 35hp motor hasnt ran in a while like some years. the guy is like 84 years old and doesnt plan on doing anything with the boat. all its been doign is sitting there. well i believe it to be a 1959 johnson 35hp but not sure. has a gold ring on top fiber glass hood. the model number is
RDS-20 serial is1776205
i havent checked compression on it and checked gear oil but in a month or two i will be checking those out. yes compression ill get u number and gear oil if metal shavings and what color it is. its not sezed but its like heck to pull lol. guess cause its a bigger motor then my ten lol
its electrice start with out generator i believe. some chipped paint on the very head where spark plugs r but i dont believe its over heated. mine has chipped paint too. doest look discolored like it over heated
the guy siad he only used it once. he traded it for a 60hp gale outboard.
how much does this motor weigh if the year is right? but man ive seen pictures of these motors and its huge in comprason to my motor!!! omg i was amazed. so any thoughts on the motors.
if i do happen to get the motor it comes wiht the boat which is made by some guy a long time ago like orlando chipper or clipper think it was called. its all alumium with wooden transome and with foam under the seats so im happy no tearing up or blah blah with all that messy nesss. the guy siad he replaced the transom with marine grade plywood and a water proof coating and fiber glass also so ill check ti also oh ya i forgot to add it has elctrice start no generaor.
how u think the boat and motor with will be worth? not running. im thinking 100-200 dollors with boat and 50 only motor idk no trailer but is it ok to keep a boat in the water? fresh. its on the same lake so i could tow
