oops!
- Oct 18, 2007
- 12,932
a lot of people keep asking me for this in pm......so here it is.
this is a structural peanut butter i use for holes in hulls...and other areas that a super strong structural filler is needed.
you can use this for bedding if you wish.....its a little strong for that....so you might add some glass bubbles to the mix.
ok.....here is the peanut butter recepie.
what you are trying to do ....is get a 75 percent filler to 25% resin ratio.....this stuff is thick.
pour off some resin....and catylize it at 2 %
IMPORTANT you always catylize the resin first...because you will never get a good resin to cat mix after the filler is added.
25% resin
50% milled fibres
25% 1/4 inch short strand fibreglass.
add the short strand fibres first.....mix it well till each fibre is wet/ or saturated
now add milled fibres.....the powder kind......this is actually ground up fibreglass...
and mix that till its all wet. there should be no dry powder in it....it will be really thick...your arm will get sore....but keep mixing....
remember....the resin is hot.....so mix fast...you will only have about 5 mins mixing time and 10 mins working time...so mix small batches till you are comfortable with the amount you are working with.
gellcoat paste
milled fibres only (powdered)
you are looking for about a 40% fiber to 60 percent gellcoat ratio.
catylize the gellcoat at 2%
add the milled fibres till you have a thinner than tooth paste consistency...mix till there is no dry powder in the paste
there ya go guys....
cheers
oops
25% resin
50% milled fibres
gellcoat paste
cheers
oops
