Re: 21.5' 1990 Campion Fishing machine transom and stringer restore
Just waiting for some 50+ weather to do the transom install. i have 2 pieces of 3/4" exterior 6 ply plywood laminated together with a layer of 1.5 oz CSM in between.
1. Should i wrap the edges in csm before installing?
2. When i install do i have this right: wet the plywood with resin/wet the skin with resin and then apply the 1.5 oz mat to the skin and wet out again/ go back and put another liberal amount of resin on the ply and then install?
3. I'll be clamping throught the scupper holes and outboard mount holes and the drain hole + some flat washers and screws through the swimgrid ect.
4. should i leave some of the csm that will be applied to the skin 4" larger and "wrap" the plywood? i'll be filleting and putting a layer of 1708 over the whole transom extending 6" to the hull on the bottom and sides
I just want to go through this thing a 1000 times before i go to do it.....
Thanks
Doug
Sorry I thought someone else would have responded by now. Been sort of envolved in my own little project (world).
1) Yes you should wrap the edges of the ply before installation. Makes it nice and water tight before you install it. Just rememder that you need to sand it after to get a good bond. So the 1.5oz mat might want to be double that thickness.
2) What I did was I painted the prefitted wood, let it sit, then repainted the wood (the wood sucked up quite a bit, just kept giving it until it was saturated) then applied a layer of 1708 biax to the wood,then repainted the biax. Leave alone and move to hull.
I played with the temps while I was doing it. The outside temps where in the low to mid 50's giving me a very long pot life. When I want to speed things up I brought it in the garage where I have gas heat. If you do not have heat use halogen lamps 250w for mid heat and 500w for high heat. Keep them away from work surface by min of 2 ft.
Mix up a batch of thickened (silica and mole hair glass) and spead on the transom hull with a carpent glue trowel. 1/4" opening in the trowel. Buy cheap, you'll through it out after your are done with it. Then take ply, double check 1708 wet out, no voids, bubble roller if need, and squish into place. Clamp and clean up excess ooze. I used it as a filleting compound around the edge of the board.
3)Yep I used the screw with fender washers. I also drill two hole near the bottom of the ply through the transom to add a couple of screws for clamping. I just pluged the hole with a screw and some 3m 5200 when it was done. Might want to add a few clamps alont the top. Do not over squeeze the glue out.
4) I would break up the one piece in several pieces. Very hard to work with a big piece of cloth. But thats me. I would do the fairing piece then cover the whole ply then anouther fairing piece extend 4" past.
Any more question just ask I'll keep watching for them. I'm no expert but I have been there and done that......
