sogood
- May 11, 2016
- 361
Mod comment: This thread is a continuation of a thread started in the Mercruiser repair forum. To see the beginning of the thread, click here -> https://forums.iboats.com/forum/engi...ter-getting-in
Chris.
iboats mod team
As to the above, the camera is in constant use. It's one of the best tools I have! And now that the original query about water ingress is turning into a total transom reconstruction, a mod might deem it appropriate to move it to the "restoration and Rebuilds" forum. Please feel free.
Today I got the exhaust Y pipe removed and surprise, surprise, it was loose, with one of the top bolts missing and the bottom ones just holding on, thanks to corrosion on the lugs. See attached picture. I can sort this out so it's not a major worry. There was no sign of any gasket or seal either!
I also got the inner transom assembly off along with the outer gimble assembly, but not without some corroded nuts shearing off, with the remnants stuck inside the gimble housing. Also not a worry as I'm replacing the Gimble assembly as previously intended. As an aside, there was no gasket or seal on the gimble assembly where it mates to the transom. Is this normal or should there be one there? I've noticed that some outdrives seem to have gaskets/seals and some don't. Am I right in this assumption and if there isn't usually a seal there, can it do any harm to arrange one?
Then I started drilling some exploratory holes, down low and close to the keyhole. I could see the rot around the keyhole opening and expected mush, which I got. So widening my explorations, I got more mush, and more mush, which continued as I went upwards and outwards. I went as far as I could without having to do any chopping, as mentioned in a previous post in relation to the two "battery ledges".
I cut away the inner fibreglass skin and found very little of the original transom. In some places it was just wet paper. In fact, when I was cutting through the glass along the bottom edge, water was actually running out of the cut.
So I'm going to have to continue cutting and chopping, just to get access to clear out the old transom material and to give me room to get the new transom in situ. It will be just under 8' wide and about 3'6" high at it's deepest point. To this end, if needed, is it possible or advisable to fit the transom in sections, as in, one skin cut horizontally at about it's centre line and then cut the second skin vertically. this means the joints are staggered. I ask this because I wont have total, clear access to the transom area. In hindsight, it might have been a lot easier to do the transom from the outside, but I wanted to avoid messing with the exterior of the boat. And removing the battery ledges means I can reinstate them properly.
That's it for the moment. I have to make up a cover for a friends boat, so I'll be alternating between that and my transom work. Some pics showing the extent of the rot.
Chris.
iboats mod team
