I have a 1973 Gibson 36' houseboat and I was removing the rear wall and window before the engine deck ( to close in and make another room.
Well, the stringers are all rotted and they came out of V formation across the 10' section of the beam. Now they are flat...and going inward upside down V from the weight of the roof pushing the walls down and it's in the water so buckling.
it appears that if I lay 4X4 across the stringers and secure the 4X to the wall I can keep the stringers from bowing inward....they are so rotten that the other methods like once ting epoxy or running bolts won't work...a beam is going to be the quick and dirty way to go. I'm a liveaboard and boat never leaves the slip so I just need it to float.
My concern and question here is....is it OK for the bottom to now be flat when it was initially slightly V and if I reinforce the stringers flat will be OK? The front few stringers are really short and still V.
I can imagine a tupperware tub being OK bulged or flat....but fiberglass....how's that going to play out?
A guy that runs a boat salvage yard says should be OK being flat just reinforce the stringers. Others are saying no fiberglass isn't supposed to move much but I know on rvs the must flex alot.
Also to be considered is that I'm only going to keep downward force on them to keep them from buckling....so that means that if theres wind or wake they can still move downward and flex back to hit the 4X...
I know most are thinking...fix it correct but in this case just imagine your poor and just need to float and need to come up with the best and least complicated solution....
